red lines the preview surface, not match the selected profiles (yellow).
Tried sweep2 loft network etc and dabbled with settings but cannot get anything keeping to the profiles.
Maybe I just didnt get the right combination of settings but is it about safe cracking ?
Looks simple enough !
Wish to place a surface through these profiles.
I need the radius curve the same throughout so did this.
did this before adding the triangular parts, now pondering on best approach with that added extra !
I then need to joint the surfaces, then offset this .25inch inwards and create a solid.
Hi Eddi,
Understood, cheers.
and the video is GREAT. I do love a video for such things.
It all goes to making a mini tutorial for everyone.
Also with the triangular extensions I now have, should I use patch or extend and trim the upper surface ?
In my example the upper edge of side surface is extended by _ExtendSrf and previous created upper/profile surface is the cutter for command _Trim
-regards
