V5
surface rotate using a profile, should one halve it then rotate, or use the full left to right shape ?
In my head if I am using U for full rotate, its going to overlap itself, whilst a half one will simply swing round 360deg and meet up with itself.
so should one slive the profile in half first ? dispense with one half, then use surface rotate ?
(the blue one) profile use half or full for rivet.3dm (64.9 KB)
If your profile curve for the Revolve is symmetrical, the resulting surface will be the same, no matter ifyou use the full curve or only half - Rhino will automatically detect that it’s a symmetrical curve and create only a single surface; so no overlap. Try it and turn on the control points to validate that it creates just the single surface (no double control points).
Cheers, look same, I wouldnt have known what a double skin looked like with control points, and as it behaved itself I still dont !
however its an ok thing to do then .
While I don’t disagree with the conclusion, it’s been since, what?, Rhino 2 that revolving a non-symmetrical curve would result in self-intersecting geometry. I’ve always found that to be a bit too much hand-holding myself…
