What is any error at save file?
Rhino Version 5 SR14 64-bit (5.14.522.8390, 05/22/2017) on window 7
3
2
Hi @l1407 do you have this problem with just a particular file? or with others as well? can you share it?
I’ve got the same error, when saving a DWG file as a 3DM. Without any VA objects in the model.
Cheers, Jaro
Hi Jaro, please share the file so we can test it on our machines. Please indicate your Rhino version as well.
Many thanks for you reply , and late reply to you
I find the leader object on layout have a save file problem, when I delete the object and save file to be no problem
(attach file for your testing)
test.3dm (248.4 KB)
@l1407 @jerry.bakowski please try that error with the new VisualARQ 2.13.1 version we released yesterday. You shouldn’t run into this problem anymore: VisualARQ 2 - Version 2.13.1 released
Many thanks for yours!
