showing 0.0
export 0.0.3dm (48.3 KB)
dimensions are linked to the current cplane (construction plane)
_cplane command will allow you to set to front or right so you can add your “vertical dimension”
can u send me a video? @Tom_P
no.
use View Front or View Right
or in Perspective
_cplane world Front
then apply the dimension command you need.
(_cplane is the command you can type in the commandline)
Black “200” and “100” dims are with world top (standard cplane in perspective)
cplane to world front, applied in perspective view
(and blue “100” dim created) - is this what you 're after ?
Or rather than set and reset CPlanes simply add the dimension in the Front viewport…
(You may need to select the first point in the Perspective Viewport to get the correct y direction positioning; and ensure you have the Planar option turned on so when you place the second point in the front view it automatically lines up.)
… what i did not know - looks like the project option is also saved in the dimension-history ( it will update even if the plane and the linked brep-vertices are not on the same plane)
