Hi there,
I am quite new to the I am trying to create a small plugin to automate a process that I do all the time.
Here is what I want to do:
- User select a closed curve (rectangle)
- Run the plugin command
- A form will come up for user to select some options for the pattern, for example, Round or square
- When user press OK in the dialog box, the pattern is filled into the closed curve.
Has anyone done something like this before??
This is what I tried, but get ObjectCount is always 0 even I have selected some object.
// Check the selected curve
GetObject go = new GetObject();
go.GroupSelect = true;
go.SubObjectSelect = false;
go.EnableClearObjectsOnEntry(false);
go.EnableUnselectObjectsOnExit(false);
go.DeselectAllBeforePostSelect = false;
go.EnableSelPrevious(true);
go.EnablePreSelect(true, false);
go.GeometryFilter = Rhino.DocObjects.ObjectType.Curve;
GetResult result = go.Get();
