What command to regroup items ungrouped without reselection?
V8
I need to get to a joined up made of many ‘bits’ curve which is a few groupings in by now, and make it degree2. It then loses the black ants on thin fishing line look.
ctrl shift click gets their bits, not the whole curve.
Is there a command or method to select the joined curve that is within a grouping, several groupings in fact, ?? then I can run ChangeDegree.
Else , if I ungroup, several times, get to the joined up curve, run ChangeDegree, make it degree2 , how can I afterwards turn the clock back to when they were grouped, i.e. before I did all that ? WITHOUT SELECTING ANYTHING, (perhaps a GroupStateManager ! ) as I dont know what else was grouped with them, its too ‘deep’ to fathom out ! so selecting the items and grouping again is not an option here, as they were grouped in a particular order as well.
Cheers
Steve
Hi Steve -
It should give you the option to select the whole curve:
