Lines types are limited in Rhino. Cant do Zig Zag lines or text with in lines.
Would be good if we can control line display in 3D view. so we dont have to use make2d to control the line type.
Do not bother with AutoCad, it is way over rated. You can get SolidEdge ST8 for free after registration. It is a 2D parametric CAD with all the tools for creating drawings. It is very relible to creat dxf or dwg files.
I think Mcneel should add dynamic blocks in Rhino 6!
Autocad is a pain, if Rhino gets a bit better in 2d-drawing then one would not need to switch between two programs. Which is expensive, slow and painful.
You can import almost anything into Rhino, you can section it or take some form of dimension and interact with it in order to aid most 2D/3D work. I haven’t used AutoCAD since V2008 so it may have changed but it was always a pain in the ass when clients supplied odd file types with mesh detail or some stuff that was already in use.
I can’t deny - my drawings are much ‘crisper’ (is that a word? sharper? cleaner?) when I output from AutoCAD. Not sure why. That’s important to my work.
Also, it’s hard to put my finger on it but when I work in 2D (which I have to do a lot) AutoCAD is more ‘definite’. I tend to work in Polar and when I draw a line it snaps to ortho much more definitely than Rhino does. I spend more time nudging Rhino to do the right thing than I do with AutoCAD.
I prefer Rhino but there are times, especially when I have a lot of 2D work ahead of me, that I bail out of Rhino to get the job done in AutoCAD
Can I add to that?
When I get near the end or mid point on a line in autocad the pick box leaps to that end ‘magnetically’.
In Rhino I need to hover very close to any snap point which is frustrating in tight quarters.
Any way to expand the ‘reach’ of the pick area?
