Hi guys, why can’t I weld the sub-d cage like I can weld a mesh?
I also see that if I ToSubD a mesh that is in a group then the result is also part of that group. It should not be.
And that if I try to subselect the SubD that is in the group then I can’t, I can only pick it’s edges. It should be subselectable from within a group like other objects are.
Hi Jorgen - I see the last two, thanks, I do not know the answer to the first question, I need to fool around a bit and see what it does - maybe nothing.
RH-58080 ToSubD RH-58082 Grouped SubD cannot be selected at the top level
