Secondly, there are no shadows appearing in arctic view even when shadows are on. When you zoom in a lot, you can see what appears to be noise of the shadow?
This is what Rendered looks like after ZEA on my screen. The only objects that bleed through are curves within the block. ClearDrawOrder on those (using BlockEdit) if it’s not intentional.
Thanks a lot Jakob! This was the fix I was looking for, and will help me troubleshoot when similar things happen. Regarding how this happened in the firstplace, I have no clue tbh. This particular file was baked using content cache from an existing file into a new file, maybe that could be the issue. I thought ZoomSelected would work but it seems to fix extents I need to use ZEA.
