Weird Shadow in Shaded Mode
does anyone here have this issue?
looks like a DARK green shadow along the edges
Yes, this is a bug with parallel views that was introduced rather recently… don’t know when it will be fixed… @jeff is on vacation I think.
@jeff - is this fallout from removing the glossy hot-spot highlight from parallel views ?
@pascal
Yes…
I’ll try to get to this sometime this week.
@pascal
At least I think it might… I’ll have to test some things.
If you CHECK the option “Use advanced GPU lighting” in the Shaded mode settings, you’ll get the proper behavior… until I can fix this properly, that’s the only workaround I can suggest atm.
-J
nope
did not work
mcneel already addressed it’s a relevant issue and they had brought up to developers’ attention
thanks
(Psst, @jeff is that developer :slight_smile: )
pascal (mcneel) already told me about the ongoing issue.
@pascal Was/is there a YT item for this? I thought there was, but I’m not seeing it on my list anywhere.
Anyways…I’ve fixed it and will be committing it shortly…
-J
