In the attached I have surfaces that I trimmed from a larger surface:
Now I do an offsetsrc Not Solid, Both sides or Flip 1/64". I curious why I get this weird extension off to the right.
Problems Offset.3dm (3.3 MB)
Hm - I cannot repeat that here so far in Windows or Mac (5.3.1).
Hi Jim - I think that is the same - are you trying in the exact same file you posted or in an original that you exported from? (not that it should matter)
The was the file I posted.
We can repeat this and it is on the list to be fixed. For now, just set Corner=Round and it should work, with the result the same as Corner=Sharp should have been.
