This issue happens when a cad file is saved using Rhino 8 and converted to a Rhino 5 and then opened in a software called Matrix 8.0 (Uses Rhino 5). After the file is opened a weird gray layer like surface appears in the middle of the screen that you can not select, delete or move.
Has anyone every seen this or know what this layer like surface is called? or how to delete it?
Hi Roger - seems like it could be the ground plane - open the Ground Plane panel and see if that is turned on, or check in the Display mode for the viewport that shows the problem
When I enter the Macro, “Ground Plane” turns OFF. Then I click the macro again and it turns ON. Then I click the macro again and it turn OFF… and so on…
Is it possible to only have the Macro change “Ground Plan” to OFF only and not OFF,ON,OFF,ON…
