I’m hoping to get a bit of help here. I’ve created several large scale sculptural seats in Rhino, the specific issue I’m having is that in one of the models, just one ‘segment’ of it will not open correctly in autocad. Neither will it import correctly into Solidworks apparently - the same segment is missing.
The model appears fine in Rhino, I can’t fathom what is wrong with it. It appears to export with no issue from Rhino, but upon opening in autocad for example, that segment is missing. Note I need to export the .dwg as a ‘solid’. It appears to be fine if solids = curves in the autocad scheme export options.
I’ve attached a stripped down version below, which is the piece that won’t export, and its neighbouring two pieces which are fine (like the other 50+ segments overall, which I’ve had no problems with).
Has anybody had this before or can help point me in a direction towards solving this issue?
Created in Rhino 5, up to date service release etc.
Hi Luke - I’d run ShrinkTrimmedSrf on all of these before exporting - I don’t know if that clears the problem, I don’t have SW on this machine, but I can try in the AM.
Hi cdordoni - That actually worked. I don’t know why, and seems roundabout, but I’ll run with it. Thanks for the suggestion!
Pascal, thanks also for the help, time, and investigation. One thing though,
It’s worth noting trying the the IP method, I see my rhino was not accepting IP / InfinitePlane. I’m definitely ‘up to date’ in terms of updates, I’m not sure why that didn’t appear to recognize it.
Hi Pascal, apologies that was unclear, yes it did come through fine as a solid into autocad.
Was that the only thing done? Opened in V6 and exported to .dwg?
