I’m trying to recreate the view from a Zaha Hadid painting (Eaton Place) in 3D but I can’t get the view right, is there an option to distort/skew/manipulate the isometric/parallel view options? I essentially need the x and z axes in the same plane as the camera while the y-axis is going off into the distance at 45°, the final step would be to rotate the rendering in Photoshop or rotate the camera (see pictures below).
Happens often (but not often enough): The task of describing your issue to someone else, especially via writing, causes the little grey cells to shift gears and suddenly the solution appears!
