The Gumball only aligns with object if i select the 4 faces with the SubD “select face filter”.
If I select the object without any filter applied , even with the “align to object” settings applied the Gumball does not align
Possible bug.3dm (40.4 KB)
pascal
(Pascal Golay)
2
Hello - that is ‘correct’ behavior. The Gumball can only align to objects that have an inherent, unambiguous plane that can be found.
Thank you for the clarification… seemed strange as it is the same object in both cases, only the way it is selected is different
