Every few days this graphic distortion happens. Can anyone shed light on why it happens and how to remedy it? Every Rhino file that is open distorts simultaneously and restarting Rhino doesn’t reset it. I have to restart my computer.
Run Rhino command SystemInfo and post the results.
Untitled.txt (6.2 KB)
Hi @arushing,
This - Apple macOS Version 15.4.1 - is macOS Sequoia, which is an OS that didn’t exist during the Rhino 7 development.
Here are the requirements for Rhino 7:
You might consider downloading the Rhino 8 Evaluation, which works well with Sequoia.
– Dale
you on on v7 on an older amd/ intel mac running OS 15.4.1 correct?
as per the v7 system requirements Os 14 was that last “officially supported” OS for rhino7.
macOS Operating Systems
- macOS 14 (Sonoma)
- macOS 13 (Ventura)
- macOS 12.4 (Monterey)
- macOS 11.6 (Big Sur)
- macOS 10.15.7 (Catalina)
- macOS 10.14.6 (Mojave)
As a Student with an existing Rhino 7 edu license, you are eligible to update to Rhino 8 edu for $95.
Rhino 8 is is officially supported for OS 15 and higher and may cure your display issues.
If you have not, please download the free v8 for mac eval and see if this happens with your file.
if not, upgrading may be worth it for this machine. If it does the same thing, please let us know.
you can get the v8 eval here- https://www.rhino3d.com/download/rhino-for-mac/evaluation/
