Given the following code:
var settings = new ObjectEnumeratorSettings();
settings.ActiveObjects = true;
settings.NormalObjects = true;
settings.HiddenObjects = true;
settings.LockedObjects = true;
settings.ObjectTypeFilter = ObjectType.AnyObject;
var objects = doc.Objects.GetObjectList(settings);
foreach (var obj in objects)
RhinoApp.WriteLine(obj.Id.ToString());
return Result.Success;
Strangely, doc.Objects.GetObjectList(settings) returns some items, but they are like empty objects in the debug inspection tab:
Is that normal?
Moreover, the property ObjectEnumeratorSettings.ActiveObjects is not really clear to me: what are exactly ‘ActiveObjects’? Selected objects? What would be the opposite of ‘ActiveObjects’?
The doc is not really helpful:
Here’s the version I’m running:
Rhino 6 SR30 2020-8-26 (Rhino 6, 6.30.20239.17111, Git hash:master @ 6b3c909b3d6e766c249ca21fcd00b31ad5432d0c)
License type: Commercial, build 2020-08-26
Thanks in advance for your hints!
