Weird boolean region result
hi. I want to split the polygon into 2. which is supposed to be a very simple case.
Weird BooleanRegion result.gh (8.5 KB)
I got a weird boolean region result here.
Does anyone have a clue? Thank you so much.
Edit
Hi @asdbeen53 thanks for reporting.
It seems an issue that I can repeat in Rhino. Logged as RH-73550 CruveBoolean fails to find the correct result
@asdbeen53
Our dev. says that Rhino should be able to handle this but there is an issue with the input:
yes. Thank you for finding that!
