Doing command booleand difference. Selecting the element to delete from is fine. But when I select the number of elements to delete with by right clicking the layer they are in and clicking select objects nothing happens.
Also, I’m not sure if this was intentional or not but if you select a block to use as a tool to delete it breaks the block down into individually selectable elements rather than clicking on the whole block as a group.
