Weighted Control Point Display - Removed?
Previous verisons of V9 WIP/BETA displayed control points with non-unity weights as diamonds rather than circles (or squares). I’m not seeing diamonds in BETA (9.0.26251.12303, 9/8/2026)
Has this very useful feature been removed? Or is it optional? If so how do I turn it on?
File with example surface and curve
CP Weight Display Example DC01.3dm (146.2 KB)
I wrote about this bad decision a few days ago in other topics, but so far there is no answer by the developers why they voted to turn this feature off by default. The removal of diamond-like display for the weighted control points has a hugely negative impact on the surface quality, because some tools cause an unwanted change of the cp weight that remains hidden for the user (forcing him or her to constantly check that manually by running the “Weight” command multiple times during the modeling session).
Instead on being a universal solution for all display modes, that setting is now made individual and turned off for every display mode. The user is then forced to turn it on manually for every single display mode one by one, which is a time-consuming process if he or she has many display modes already in use (like me, as I have over 125 of these).
Current solution: Go to the following setting on each display mode and change it this way:
Rhino options > View > Display modes > (expand the preferred display mode) > Objects > Weighted control point style > Set it to "Diamond with white center"
Unfortunately, there is no global setting to set the Diamond-like display of the weighted control points for all display modes simultaneously. Having an advanced setting for that would be a nice feature.
Here is one of the topics where I wrote about the importance of having a proper display for the weighted control points by default. Other posts in the same topic show examples where even a single weighted control point prevents the user from achieving a proper surface continuity on multiple surfaces.
@Rhino_Bulgaria Thanks.
For anyone else looking for this here is where to find it (Shaded Display Mode example):
While waiting for McNeel to provide a friendlier solution, here’s a python script that will quickly set weighted CPs to diamonds for all display modes in the Beta. Before running it, do consider whether you really want all display modes updated! Use at your own risk.
SetWeightedCPStyleToDiamond.py (925 Bytes)
Regards
Jeremy
Thank you, Jeremy! At first my Rhino froze for a long time and crashed, most likely due to the high count of display modes that I have, but then I tried again and your script worked as you described.
I noticed that after running the script all of my custom display modes are now marked with thin black names in the vertical list (some of them used to have a thick blue name), whereas Rhino’s own display modes are all marked with thick blue name, which is the way Rhino indicates that a display mode is modified.
Is it possible to make a similar script to set the wireframe thickness (Scale) of all display modes to 1 instead of the default 2? Not having a global setting for this is a real pain.
I don’t know why that would be, maybe something else changed in the Beta re how non-std display modes are handled? I would check one or two out in detail to make sure we’ve not inadvertently changed anything we shouldn’t have.
Yes that should be possible. I’ll take a look.
OK, here’s a python script to set the Surface Edge Thickness Scale to 1 for all display modes:
SetSurfaceEdgeThicknessScaleTo1.py (984 Bytes)
Incidentally, it appears Rhino sets this value for display modes like Pen that don’t actually display this setting. This script does so too.
Thank you! This script also works like a charm. Cheers! :clinking_beer_mugs:
