It’s inside Rhino 6 and Rhino WIP!
If you are using Rhino 6, the command to use is TestPackageManager
Ifyou are using Rhino 7, the command to use is PackageManager
Hi, guys. I know perfectly how to install Weaverbird through package manager.
The problem is I don’t have Internet access on my working PC, Is there a way to download on another pc and copy the installation files to my working PC which have no internet connection.
Thank You
The best option that I can think of will be to download the package directly, copy to your other machine and install the contents manually – change the extension to .zip and unzip into Grasshopper’s Libraries folder.
https://files.mcneel.com/yak/packages/Weaverbird-0.9.0%2B1-yak-and-mac.yak
is there a way to obtain weaverbird in rhino7?
Absolutely! Simply fire up the PackageManager
, search for Weaverbird, and install it! Then relaunch Rhino.
Easy peasy!
thank you!!
I am not Mc Neel. I don’t know where is this documentation and this functionality is still visible.
Hi there,
I am trying to install weaverbird but package manager command doesn’t work on rhino6. Is it something I need to download separately?
Thanks
Hi @user54
You can also download Weaverbird directly from Giulio’s site:
https://www.giuliopiacentino.com/weaverbird/
thank you! I managed to install WB
HELLO plz I need a help as soon as possible
I have rhino 6 and I am using this link to download weaverbird for it Weaverbird – Topological Mesh Editor | Giulio Piacentino
I have also tried (Alternative download available if you don’t have admin rights).
and it is not working it gives me the following msg as shown in figure what should I do
plz a help
plz a help
yes not working
Hi Fatima -
Could you please run the Rhino SystemInfo
command and copy-paste the result here?
Rhino 6 SR0 2018-1-16 (Rhino 6, 6.0.18016.23451, Git hash:master @ c0b115e88c59340755c25f7822e172c79c9b530b)
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 472.47)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2021
Driver Version: 30.0.14.7247
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
Hi Fatima -
Yes, that won’t work. You need to update to the latest Rhino 6 Service Release.
