Weaved structures
Hello!
I hope one of you clever people here might be able to help me out here!
I’m trying to create a sort of weaved pattern in grasshopper, based on the surface (I work in mm, and the surface could be archway or tunnel or very elaborate shape, at least 2m high and 4m long). The idea is to create the form out of rods. The main rods are 20mm dia, and they form the main structure, the thinner diagonal rods are 7mm and they form the diagonal pattern in between. The weaving could be any form, but all the rods needs to stem from the ground. Could someone suggest a good way to achieve that please? It’s absolutely frying my brain trying to figure this out and I’m sure it would take like 5 seconds in Grasshopper!
Many thanks
Ps. I forgot to mention I’ve been experimenting with LunchBox so far :slight_smile:
Pretty sure the correct term would be ‘woven’ and not ‘weaved’…
No its not 5 seconds, I assure you. Please attempt to make something yourself first.
Right now is “do my job for me”.
It is a well known topic
Oh wow, so many people are interested in this! That’s kinda awesome! Thank you for sending these links dfytz1, I will read through in hope someone there’s a solution for me somewhere there! Many thanks
One more link for you, with different approach and updated file
https://www.giuliopiacentino.com/knitting-pattern/
stockinette-pattern.ghx (225.3 KB)
