Hey there, I am quite new to setting up macros in Rhino and wanted to ask if there is an easy way to have the textual output of a command like _EvaluatePt filled into the clipboard? And if so, how to do it?
Thanks in advance and greetings!
Hi -
No, generally, there isn’t an easy way to do that.
Hi @Scan3D_GmbH,
Drag and drop the attached script file on top of a running Rhino for Windows.
Then run CopyCommandHistoryToClipboard
CopyCommandHistoryToClipboard.rvb (359 Bytes)
Also, just doing _-CommandHistory _Clipboard
basically does the same thing…
– Dale
Thanks for your answers! I took the longer route and got it workig with some Pythonscripting. If anyone is interested in it just hit me up.
