But, in my exercise I need to apply the same feature (wavy lines and fade it out on the contour) but on a Trim Surface (you can see the image). I’m really lost about the process to do that… Any idea or help it wil be very appreciate.
Hi @dowazura !! Many thanks for your help! That’s the result that I wanted to get
I’m trying to apply your definition to my base surface (is another different Trim surface) and it doesn’t works. I’m checking the definition and I can’t see where’s the problem… Its just a matter of replace the base surface… Do you see where is the mistake?
I’m stuck with another shape where I want to apply wavy lines on a trim surfacer. I’m using your definition but this time I have a problem on the limits of the shape. I hope you can give a hand, I’m a bit frustaded because I can`t find a nice solution.
I need to get a continuos limit (you can see the image)
How can I increase the fading on the limit. I want to increase the area of the fading
