Watertight Polysurface
Hello dear Rhino-Forum,
I tried to correct all open edges by remodelling concerned faces (following “filerepair for watertight parts” by K. Houchens), but there are still two points (edge analysis// naked edges).
Is it possible to close the object without remodelling 3 faces involved (6 faces mirrored)?
How do I solve this problem to be able to create the negative- shape to mill?
Thank you very much for your attention.
Greetings
Fabian
Hello- in this case use RemoveAllNakedMicroloops to clean up.
Hello Pascal, great - worked - thanks a lot!
Greetings
Fabian
