Hi Guys, i trying to create this pattern for university exercise, i used flow analysis to create curve and try use like a attractor but, i am unable create the uneven flow which is in tha pattern ,
can anyone please help me with this, Thanks in advance
please post whatever you have already tried, even if it did not work as you wanted, so we can start from there
at this link you can find many many pictures of that lamp produced by drag and drop design studio in Romania:
[edit] by the way, the lamp is designed by Madalin Gheorghe, which is a name that might mean nothing to many, but he was the teacher of MANY webinars I followed on Design Morphine in the last years, expecially about cellular automata, particle systems, growth and so on terrific guy!
Ok, so the first thing is to try and find any regularity in the original. Obviously the base geometry is a Revolved surface. It looks to me like there is a bifurcation pattern overlaid, with the length of each âlobeâ in each level being random. One side of each upper lobe ends up being the top edge of the lobe below.
Starting from a grid of points, you can specify all the curves on and projecting from, a flat surface, create the lobes with Network or Edge Surface and then use Sporph to distort them onto the revolve. Then itâs just a matter of introducing some randomness in the right order.
Iâll have a play around with this myself, but Iâd be interested to see how you get on!
looks like each tentacle/crest has its sort-of up/down behavior along its path, so maybe thereâs some sort of loftp going on which inflates the section curve a little bit at railâs middle length?
A quick idea I entertained for a sec, but canât test today , and also related to what @Tom_Newsom highlights as system, would be to do some varying contour âtiersâ along your surface, 2D to 3D (sporph) or directly on the revolved shape, then create + alternate bumps/folds somehow(?):
Note: jokes aside maybe it pays to edit your topic title to allude to texture creation - many water and ripples topics on the forum already, passersby might roll eyes thinking itâs that again. Cheers!
