Hi, I’m trying to export a mesh to IGES file but I got this error message, I was able to do this like 3 month ago but not any more, did I miss anything? Any input is appreciated.
Are you sure you exported meshes last time?
Yes, I exported mesh last time. Is there any other approach I can use on this?
It’s highly unlikely that you were able to export a mesh as *.iges since the file format doesn’t support it. Unless I’m completely wrong
What you can try is quad remesh and tonurbs. The resulting polysurface can be exported as *.step or *.iges
I think you are correct, I just tried dxf file format, it worked for me. That might be what I did last time.
