Warning 1946 (2)Property 'System.AppUserModel.ID' for shortcut 'Rhino 8
My big moment…
Installed Rhino V8 then the update, got this warning,
has anyone else experienced this ?
warning 1946 (2)Property ‘System.AppUserModel.ID’ for shortcut ‘Rhino 8.lnk’ could not be set
for other progs its said its a windows 7 thing. and a fault of the program makers.
though I am win 10 64bit pro.
should the install be tweaked by McNeel ?
Cheers
Steve
This warning has been experienced on this forum before - you can ignore the warning. I think it has already been addressed in a later version.
V8
Not so it seems, as it happened when installing the update after the initial version was without warning.
I shall ignore, but McNeel note it came with the update.
Cheers
Steve
I meant later installer build meaning one that is not yet service release (maybe even not yet service release candidate)
I’ve been getting the same warning the past couple of updates, including the one today:
It usually appears twice during the install by the way. Any updates on this issue?
Hi Anders -
No. We have it on the list a few times and I’ve added this thread to the only one of those that can be set to public viewing → RH-82041 Installer: Shortcut errors during install
RH-82041 is fixed in Rhino 8 Service Release 8 Release Candidate
Just got the error on today’s build again:
Yes, Marika opened RH-82041 again yesterday. For some, this appears to work, for others not. I’ve personally never seen that warning but I’m not getting the (related) SafeMode shortcuts on my system…
I got the error on Rhino 8 SR11 update. (8.11.24226.06001)
Got it when reinstalling from packaged downloaded few minutes ago.
Same here, just installed the advertised update and this window popped up:
Anything to do here or just ignore?
Hi -
RH-82041 is still open and something to be looked at, but, as far as I can tell, you can just ignore this warning.
Came across the same issue yesterday:
me too,
8.15.25019.13001
Rhino 8 SR15 2025-1-19 (Rhino 8, 8.15.25019.13001, Git hash:master @ 74164bdf5469c2f269746857c54b8c44b74c7b24)
License type: Commercial, build 2025-01-19
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 63GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon RX 6800 XT (AMD) Memory: 16GB, Driver date: 11-20-2024 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 24.10.27.02.241120
> Accelerated graphics device with 7 adapter port(s)
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 11-20-2024 (M-D-Y).
> Accelerated graphics device with 5 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 11-20-2024
Driver Version: 32.0.11027.2001
Z-Buffer depth: 24 bits
Total Video Memory: 16337 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_ACAD.rhp “AutoCAD file export : export_ACAD”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.15.25019.13001
C:\Program Files\Rhino 8\System\netcore\export_PDF.rhp “PDF Export” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.15.25019.13001
Still there: Warning 1946. (2)Property ‘System.AppUserModel.ID’ for shortcut ‘Rhino 8.lnk’ could not be set.
Hi Grant -
Yes, this ticket is still open: RH-82041 Installer: Shortcut errors during install
As you can see, this is not something that will be looked at for Rhino 8.
Same error here ;/
Sep 2025 …. just updated Rhino 8 and got this message too. In fact, I got a similar one on each of the several latest updates I installed. I think it is related to the shortcut or icon that launches the program - and is fully ignorable, but it remains an issue that should be addressed.
