Is it possible to modify the isocurve line in the direction of the XYZ axes?
Side note: I know you can force the trim and mirrors to match.
Hi Hiroki - you can try this -
PlanarFaceDirection.rhp (17 KB)
Unblock the rhp file in Windows Explorer (Properties) then drag and drop onto an open Rhino window.
The command is PlanarFaceDirection
You probably want the CPlane option in this case.
