At an intersection between two walls (as in the picture attached), how can I choose the intersection’s priority (which one crosses over the others?) When selecting them, the wall join option obviously doesn’t appear.
It would also be interesting to be able to simply overlap them (I’m thinking of the demolition and reconstruction phases)
Hi @fn_a the order these walls intersect each other depends on the order they were created (considering they have equal conditions: same style or same Layer Core/Normal type). The first one has priority over the next.
The wall joint is not detected when walls intersect in a mid point. So unfortunately right now it is not possible to change that order once the walls have been created.
It would also be interesting to be able to simply overlap them (I’m thinking of the demolition and reconstruction phases), do you have an alternative solution to get it?
