Wallacei time running
How can I speed up the analysis in Wallacei plugin in grass hopper environment? Even when I tried it with advanced computers, it made no difference. Are there any settings to attribute the CPU usage of the system to the plugin?
Usually it depends on the calculations of the objectives you are doing. I ran a solar heat gain calc using honeybee and that took few days, it is not Wallace I but it is the other elements in the definition that contribute to the slowness
Thank you very much for answering
You welcome. One way to determine which grasshopper components is caused is by using the profiler widget or running bottleneck navigator in metahopper.
