Wall vs Slab
I was lead to believe by your website that a core slab when intersecting any type of wall, normal or core should have priority. This is not happening - see attached. Has this intersection priority shifted with the latest version? The slab clearly should take precedence and it is shown with the handles but it is not. Is there something I am doing wrong here? Thanks
Hi @avatarlucas a slab layer has priority over a wall layer unless the wall has a Core layer and the slab a Normal layer. We changed this behavior in the VisualARQ 3.11 update, so make sure you are not using a previous version. If this is still not working for you, please share the 3dm file so we can investigate what’s happening.
