Wall-Slab priorities | Sidings, Paint & more
okay, I lost my mind before. BUT, the confusion started when i started drawing walls (not curtain-walls because of the limitation presented in this thread: Curtain Wall alignment - different system than Wall alignment?
I use ceilings with hidden air-void layer. Normally - in the past - I believe we had walls as priority 1 for intersections. Because of the changes after 2.11, while I was trying creating sidings with walls inside hidden slab layers, the walls were dissappearing.
wall-inside-slabs
wall-inside-slabs-1-ezgif.com-resize
So, sidings with CWs is not something that can work because of the alignment limitations. With walls, I should have the slab without the air-layer, but actually the air-layer is handy and the way it should be created because the structure of the ceiling relies inside that gap in reality. Of course walls is not optimal because of small distance with the walls in the perimeter of the building. Rhino geometry is not flexible at all so it’s not an option. I’ve tested with beams, slabs with the desired height, siding is problematic.
The absolute rule of setting priority to slabs (or walls) in intersections, maybe should be studied for a possible improvement.
