Wall Reference Line is not recognized using the Favorites Input Node. The only option available at the moment is Center Line so consider it the Default option at this moment. Tried to use it as a work around due to the fact that Walls remain locked even if it is not the case in the Layer Settings window.
Issue persists with Beta Version.
Hi @Changmarin,
this is just to quickly reply to this thread as well, and add a link to the GH-ArchiCAD connection forum.
If you start a discussion there, could I ask you to add a link to it here? This would be tremendously helpful.
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
I’ll give it a try Giulio.
