Sometimes I get this error in the joints of the walls, I’m new to the plugin, so I’m not sure what to do to fix it, if I model the same thing in Revit I don’t get this error.
This happens to me all the time.
Need a fix.
Also, recheck your model, sometimes it happens not because of bug.
Hi, this kind of issues might be fixed changing the position of the wall end points, editing the joint type (selecting the walls involved in the intersection) or editing the “Cleanup radius” of the walls. Avoid having values near to 0. You can find the “Cleanup radius” property in the Properties panel after selecting a wall.
