Wall Hatching Doesn't Print in details when Multipage Printing
It’ll print the hatching on whichever layout is displaying in Rhino at the time of printing, but the layouts not currently displaying have no hatching.
From the page currently displaying:
From any other page:
Hi @Djhg,
Could you let me know which version of VisualARQ you are currently using?
Also, could you check the following:
  • In the layouts, is the cut plane for the level active?
  • Have you checked the hatch scale? It’s possible the scale is too large and that’s why you’re not able to see it.
    To help you better, could you please send your 3dm file to our technical support email, visualarq@asuni.com?
    Best,
    Melissa
I’m using the current version, on Rhino 7.
The cut plane is active in all the layouts, so it’s not that or a scale issue; the hatch prints properly on any layout printed individually.
The hatching doesn’t print only on layouts which are not open/active but selected to be printed with “Multiple Layouts” is chosen.
I have noticed that when a layout is opened/active the wall hatching in a cut plane doesn’t display until a detail is activated, after which it will display (whether the detail is activated or not) until the layout is closed/deactivated. When the layout’s next opened/activated, the hatching doesn’t display until the detail is activated again. I’m guessing this is related. I’ll send the file.
