We cannot finish one wall of a dormer window. I will send you the file.
Regards, Simon
Hi Simon,
The problem here is the height of the facade wall, because even it has been extended to a lower level it is still generating the joint with the other one. To fix this, the height of the facade wall should be reduced until the roof edge or below.
Kind regards
Thank you. It works fine.
Regards
