Waffle structure Help
Hello all my Rhinoceroses, is anyone a grasshopper expert?
Im trying to make this into a waffle structure with slits.
I am able to get the waffle sections from the brep like this:
But when i try to create the waffle “slits” such as this example image here:
i get nothing on my actual shape. I suspect it is something with my boundary boxes having a problem:
Does anyone know how to make it work?
Thank you!
testmodel RHINO Model.3dm (1.5 MB)
TESTMODEL WAFFLE GRASHOPPER.gh (23.6 KB)
A good first step is to share your files.
Good idea! just updated the post (:smile:
I guess Opennest is not really needed in your definition, correct?
I think you need to offset the surface in Rhino instead of moving it up vertically because that does not lead to consistent intersections.
In this part I would eliminate empty paths and then don’t flatten the input of the Boundary Surface components.
Not sure what you want to do next.
TESTMODEL WAFFLE GRASSHOPPER.gh (28.2 KB)
did you achieve the slits where you can put them together? I cannot see any in your structure
If I were you I’d first fix the input surface.
Alternative.
TESTMODEL WAFFLE GRASHOPPER a.gh (38.8 KB)
Yes I see you made the waffle structure work but it needs to have slits between each section.
Do you mean this?
TESTMODEL WAFFLE GRASHOPPER b.gh (33.8 KB)
hi
why don`t you check out bowerbird
https://www.food4rhino.com/en/app/bowerbird
TESTMODEL WAFFLE GRASHOPPER c.gh (651.3 KB)
