VTK what are my options?
Hi I am developing a plugin on Mac and have the following issue when trying to use vtk via activiz:
Getting restore information for project /Users/darrenlynch/Projects/External Building Aerodynamics/External Building Aerodynamics/External Building Aerodynamics.csproj
Running restore with 8 concurrent jobs.
Reading project file /Users/darrenlynch/Projects/External Building Aerodynamics/External Building Aerodynamics/External Building Aerodynamics.csproj.
Restoring packages for /Users/darrenlynch/Projects/External Building Aerodynamics/External Building Aerodynamics/External Building Aerodynamics.csproj...
Restoring packages for .NETFramework,Version=v4.8...
Resolving conflicts for .NETFramework,Version=v4.8...
Checking compatibility of packages on .NETFramework,Version=v4.8.
Checking compatibility for External Building Aerodynamics 1.0.0 with .NETFramework,Version=v4.8.
Checking compatibility for Grasshopper 7.32.23221.10241 with .NETFramework,Version=v4.8.
Checking compatibility for Microsoft.NETFramework.ReferenceAssemblies 1.0.3 with .NETFramework,Version=v4.8.
Checking compatibility for Newtonsoft.Json 13.0.3 with .NETFramework,Version=v4.8.
Checking compatibility for RestSharp 110.2.0 with .NETFramework,Version=v4.8.
Checking compatibility for System.IO.Compression 4.3.0 with .NETFramework,Version=v4.8.
Checking compatibility for System.IO.Compression.ZipFile 4.3.0 with .NETFramework,Version=v4.8.
Checking compatibility for YamlDotNet 13.4.0 with .NETFramework,Version=v4.8.
Checking compatibility for Kitware.VTK 9.2.2023.803 with .NETFramework,Version=v4.8.
Package Kitware.VTK 9.2.2023.803 is not compatible with net48 (.NETFramework,Version=v4.8). Package Kitware.VTK 9.2.2023.803 supports: net7.0 (.NETCoreApp,Version=v7.0)
Checking compatibility for RhinoCommon 7.32.23221.10241 with .NETFramework,Version=v4.8.
Checking compatibility for Microsoft.NETFramework.ReferenceAssemblies.net48 1.0.3 with .NETFramework,Version=v4.8.
Checking compatibility for System.Text.Json 7.0.2 with .NETFramework,Version=v4.8.
Checking compatibility for Microsoft.Bcl.AsyncInterfaces 7.0.0 with .NETFramework,Version=v4.8.
Checking compatibility for System.Text.Encodings.Web 7.0.0 with .NETFramework,Version=v4.8.
Checking compatibility for System.Buffers 4.5.1 with .NETFramework,Version=v4.8.
Checking compatibility for System.Memory 4.5.5 with .NETFramework,Version=v4.8.
Checking compatibility for System.Numerics.Vectors 4.5.0 with .NETFramework,Version=v4.8.
Checking compatibility for System.Runtime.CompilerServices.Unsafe 6.0.0 with .NETFramework,Version=v4.8.
Checking compatibility for System.Threading.Tasks.Extensions 4.5.4 with .NETFramework,Version=v4.8.
Checking compatibility for System.ValueTuple 4.5.0 with .NETFramework,Version=v4.8.
Incompatible packages: 1
Package restore failed. Rolling back package changes for 'External Building Aerodynamics'.
Are there any ways around this?
Best,
Darren
