Using the latest VRay on MacPro and it only sees the actual cores and not the virtual cores. It used to see the virtual cores as well. Any ideas?
HI,
There’s a setting if you’re using Light Cache, Number of passes, that if set to 0 will make use of all the cores available.
Not using Light Cache. Don’t see any settings for the number of cores used.
