I’m working on a i9 processeur and 32Go RAM ( 4 x 8 Go) Desktop Machine.
When i render, i only get 16 threads and i can not find a way to use all the 32 Go of RAM.
Is there a way / Setting to configure the system as on 3ds max to use the maxim of ressource?
What kind of i9 you have there ? Only i9 X and i9 XE families have more than 8 cores (16 “threads”).
I don’t think I understand the bullet points correctly. Having tons of RAM also require to put in something there in order to “use” it. Are you sure your scene actually needs 32 GB of memory ?
I totally do not understand the second bullet point (especially in relation with the first one)
Please be more specific
@JimCarruthers is correct, KF series has only 8 cores thus 16 “threads”
To utilize both the CPU and the GPU together, you have to switch to the GPU engine and check both the graphic card(s) and the CPU
