walther
(Andreas Walther)
May 19, 2022, 8:42am
1
Hello grasshopper users,
I have a problem with the Vpipe command. I would like to use percentage values instead of the default absolute input method.
I did a little video to better describe my problem.
Boxwood pattern generator.gh (14.0 KB)
Boxwood-generator-test-01.3dm (1.5 MB)
Thank you for any feedback
Just a quick thought before downloading the files.
Please try right clicking the C input of the VPipe and click Reparameterize.
walther
(Andreas Walther)
May 19, 2022, 9:03am
3
Hi Martin,
thank you for your help… I just did what you said, but than the pipes disappear altogether… what does Reparameterize do?
It makes sure the curves have a domain from 0 to 1. I’ll take a look at your files in a few minutes
walther
(Andreas Walther)
May 19, 2022, 9:05am
5
I was able to extract the length of one of the curves, could this value be used to limit the slider?
excuse my basic questions I am not very experienced in GH…
The t inputs have to be within a domain of 0 to 1 like the curves. So if you want to specify multiple radii, for example at the middle of the curve you would need to provide 3 inputs for t (0, 0.5, 1).
Boxwood pattern generator.gh (18.1 KB)
walther
(Andreas Walther)
May 19, 2022, 9:17am
7
Thank you so much, now it works…!
Glad I was able to help you. Please click on the solution button in a post above so other users know this topic has been solved.
