Voronoi pattern on object-Problem with Patch Component
New to Grasshopper. Trying to apply a Voronoi pattern on a cylinder type object. Hoping someone can look at the attached files (zip attached) tell me why there is an error with the Patch component. Thanks in advance. Ed
Voronoi Cylinder Lamp Problem 2-28-25.zip (941.1 KB)
Voronoi Cylinder 2-28-25 Edited v0.gh (32.6 KB)
Use Surface Spit instead of Patch.
Patch in Rhino will not work as your expectation.
Quan, Thank you! I’ll look this over. Appreciate the help.
