Voronoi_Checkk1.gh
I am having this diagram(Voronoi) and I want to export it to .stl file…Do someone know how to do that?
Also I need to create mesh in that structure.
if you download above file then
1)in rhino create a 505050 cube
2)set that geometry in Grasshopper GEO
you will see the structure…
Here’s a quick fix that does not require Rhino geometry and also includes an alternative approach. You can bake either result and export that from Rhin as an STL. But if you want to 3d print the result you’ll have to use a resin printer because there is no way to add supports for all the internal structure.
Voronoi_Checkk1-bb1.gh (16.8 KB)
I really appreciate it. Thanks Man
