I created 4 surafes to form a ecliptical model.I need to calculate volume of the eclipse using the surface as boundary. Brep couldnt create a closed brep from those surfaces, tried Brepjoin it didnt worked.
Fix your seams so that they can join.
No one can check without your file…
I have no way to evaluate your image for volume, it is 2D on my screen.
Sorry I attached my files
Cabral Yard.3dm (3.7 MB) CY.gh (7.5 KB)
It seems there are naked edges which are the cause of your problem.
I don’t exactly understand how you created this geometry, anyway according to the edge conditions,
your input geometries for this were probably bad (not planar at both sides…).
I’ve fixed one of these edges and make the curved surface by using Sweep2.
CY_re.gh (108.9 KB)
Thanku Kim…I used Railrevolve to make that…I’ve been using rhino from last week only
