Hi guys,
I am having some issues with Visualarq not displaying edges past a certain zoom-in factor and therefore making detailed model manîpulation impossible. Here are images displaying the issue. The first is when zoomed out, the second is zoomed in. I made sure to include “normal” geometry side by side so that you can see the issue…
Thanks in advance for your feedback!
Raymond_
See below a video of the issue in question…
Rhino geometry allows me to zoom in while VisualArq wall geometry dissapears at zoom in…
I have already tried the following without success:
Reset view port properties to default
Start a new file with a new template
Purge the file
Turn off VisualArq plugin / restart Rhino / Turn on VisualArq plugin
Still… no luck…
SOLVED -
Had to update VisualArq plugin to latest build manually…
