When using Isolate from the VisualARQ Level Manager, objects from other levels are correctly hidden, but their associated VisualARQ Tags remain visible.
The issue occurs with both the default VisualARQ Tag Style and a custom Tag Style using a Rhino block as its graphical representation.
Expected behavior:
Tags associated with objects hidden by Isolate Level should also be hidden.
Actual behavior:
The tags remain visible, even though the objects they describe are no longer displayed.
Hi @badileanu and @Kida, this may happen because these tag objects have their “Clippable” status Off (in the Section Attributes section, in the Rhino Properties panel) :
But I agree that the default behavior needs to be changed. Having to manually enable “Clippable” on tags just to get the expected result when isolating a level is very unintuitive and confusing.
This should work correctly out of the box, without requiring users to discover and adjust an unrelated property.
