VisualARQ Tables – Worksession Reference Objects Not Included
I’m testing a BIM workflow with separate Rhino files for each floor, attached through Worksession.
VisualARQ correctly uses referenced objects for sections and can read their BIM properties, including quantities. However, Tables seem to ignore these objects.
I confirmed this by comparing an automatically updated table with one containing only ground-floor objects. Both returned identical quantities.
Is this an intentional limitation of VisualARQ Tables, or a bug?
Consolidated quantities across Worksession files are essential for this workflow.
Automatic table vs. ground-floor selection (ground-floor is the active file)
Upper floor wall properties
Hi @badileanu VisualARQ tables don’t detect objects in non-active worksessions. Same happens with the VisualARQ selection commands or with objects inside blocks or external references. This is a known limitation and difficult to implement.
Hi, and thanks, Francesc!
I understand this is difficult to implement.
I’m exploring Worksession mainly because of the current Level Manager limitations regarding visibility and editing control.
Unfortunately, VisualARQ tables cannot include objects from referenced files, so this alternative is also incomplete.
Ideally, either Level Manager should provide more predictable control over floors, or Worksession should be better integrated with VisualARQ’s BIM functionality.
I hope at least one of these approaches can be considered for future development.
