VisualARQ table too long to print
Is there a setting available to automatically split or wrap overly long VA Schedules to match the drawing’s height? This is needed to properly print the Quantity Calculation Reports.
Hi Yoko, I’m afraid it isn’t. You can explode the table (_Explode), so the block becomes texts and lines, and therefore move the text or trim the table lines as you wish. But of course this will break the connection between the table content and the 3D model.
You can also insert a table to a model space. Then, within a layout you can add two (or more) details, each with a part of your table. The same way you can keep a header for each “table” detail.
Cheers, Jaro
Hi Jaro,
Thank you, good idea.
Hi Jaro,
Thank you for replying.
