With wine-staging 11.14, we’re able to install and run Rhino 8 as well as VisualARQ 3 with only a few hiccups left. More details can be found in this thread: Rhino on Linux - Technicalities
While activating Rhino itself through a cloud zoo license is no problem, I’m unable to activate VisualARQ through this same cloud zoo which has an available license. Never had any problems on Windows machines at all.
I already tried different settings, changing the license mode to another mode and back, disabled the firewall, etc. But without any luck. I also looked into log files using WINEDEBUG, where I could find Rhino itself succesfully connecting to cloudzoo.rhino3d.com via TLS, but VisualARQ only connecting to stats.asuni.com but not the licensing server. I could find no error messages.
Would be great to have VisualARQ working through Wine just as well as Rhino does now. Linux is gaining in popularity fast and I’d really like use VA as my go-to BIM software there as well!
Hi @korbireischl . Glad to see this topic. I hope the VA dev team will have a look on this. Maybe sharing the installation and configuration steps for wine will prove to be helpful, in order for them to be able to reproduce it. Plain wine or through a wrapper software using a specific wine build?
In the meantime:
Would you like to share your experience using rhino with linux? Iss it stable enough and 100% operational? Is the scripteditor operational? Are scripts running smoothly? Grasshoper plugins and block attributesalso are working? Are u using R8? Have you tested R9beta yet? We’re you able to try visualarq with trial license?
I’m running Arch Linux with Gnome DE and the plain wine-staging package without any wrappers. All patches of @ItHasLegs have been merged to Wine and the installation is straightforward. Just create a fresh wineprefix and install Rhino and VisualARQ in it. The exact steps can be found here: Rhino on Linux - Technicalities - #92 by ItHasLegs . To install VA through its MSI installer, use this command while in the wineprefix: wine msiexec /i /path/to/VisualARQ3-Rhino8.msi
No winetricks or other adjustments needed. Wine creates a .desktop file automatically, so you can simply launch Rhino and VA from the start menu after the installation. In the Technicalities topic, there’s also a fix for black menus: Rhino on Linux - Technicalities - #101 by Eugen .
Rhino through Wine seems quite stable and maybe 90% operational. I noticed that viewports often don’t refresh automatically e.g. when changing something in Grasshopper, so you’d need to zoom or move it a bit. Also, zooming feels a bit janky. When zooming back in after zooming out, the viewport first zooms one step out before zooming in. And, while hardware acceleration is there, rendering is only available through the CPU but not the GPU. Still, the overall experience is quite smooth!
I haven’t tried Rhino 9 beta yet. It is possible to use VisualARQ in viewer, evaluation, and presumably also in standalone mode (I haven’t tried the latter yet, but @Eugen mentioned it). License activation through Cloud Zoo fails though.
It would be great if someone from Asuni could look into this. I’m not expecting full Linux support, but being able to run VisualARQ on Linux via Wine would definitely influence my decision to purchase a future VA4 upgrade!
